Creaky front struts
Old Dec 11, 2005 | 11:49 PM
gillly's Avatar
Default Creaky front struts
Had a blast today in the snow up here is SE MI. Went through some deep ditches with the new used quad. It is a 4x4 2000 Magnum. I noticed on the way home the struts have started to make a creaking type noise when you hit bumps or dips where they would have to compress to absorb shock. Is it normal for them to creak when it's cold outside? Never went through any deep water just plenty of deep snow. I don't believe there is anyway to oil them and just wonder if this normal in the colder weather?
Old Dec 12, 2005 | 12:04 AM
JASON420Z's Avatar
All polaris' I've ever seen have squeeked winter or summer it squeeks at the upper mount usually. My scrambler and my new sportsman both squeek. I just spray them down with wd40, it usually works.
Old Dec 12, 2005 | 12:23 PM
ScramblerXLE's Avatar
Another solution is to jack up the front and unbolt the struts at the top. Then clean the whole area, i'm sure you'll find LOTS of dirt and mud up there. grease it with some good grease and re-assemble, had to do this once to my scrambler. hasn't squeaked since.
Old Dec 12, 2005 | 02:02 PM
gillly's Avatar
You guys are right on target. The sound does seem to come from the top of the struts and is a squeaky type noise. I will have to take a closer look at them and see what you are talking about as far as unbolting them from the top mounting. Probably take them apart once it warms up a bit and spray them down with WD-40 in the mean time. Thanks for the replies...
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
