Sp 800 problem
Old Dec 12, 2005 | 02:31 AM
Atv37's Avatar
Default Sp 800 problem
I noticed sometime back that my 05 800 EFI would sputter sometimes while messing around the yard but on friday I was trying to back it up so that I could pull my fisher plow out and it just died, I got it started but it shuts right down and the check engine light came on (warranty just ran out) a friend of my thinks that it could be a bad spark plug, where is it located? (still running original) but only have like 30 miles on quad. It starts sputters and then dies, need help please I am a rookie.
Old Dec 12, 2005 | 02:46 AM
IdahoVinnie's Avatar
Normally I'd ask a stupid question like "Is there fuel in the tank?"
In your situation, you said that the check engine light came on. There may be a failsafe program built into the computer that won't allow the engine to operate, for fear of engine damage. (Possibly caused by low oil level or pressure, low coolant level, etc.)
Hopefully someone with more knowledge will be able to be more specific.
Old Dec 12, 2005 | 02:58 PM
Cutty's Avatar
I remember seeing someone else on one of the forums with a similar problem. Ended up being the fuel pump. If it's like the one I just replaced on my GMC Yukon this weekend it's in the tank.
Old Dec 12, 2005 | 06:19 PM
Polaris500HO4x4's Avatar
Check the slack in your ETC
Old Dec 12, 2005 | 10:15 PM
xler8ion's Avatar
There is a diagnostic mode you can enable which allows read out of error codes just like a car with a scanner on your speedometer pod. If you have a service manual the codes (if any are displayed) are listed inside the book. It's a good place to start. I believe your owners manual decribes the procedure for the diagnostic mode but not the code translation but the service manual has it all. I have an 800 but am not at home yet where the manuals are to be more specific.
Old Dec 12, 2005 | 10:40 PM
spyder6's Avatar
you have to turn on and off your keyswitch 2 times in succesion and then turn it on a third time right afterwards and it should go into diagnostic mode and cycle through the numbers
Old Dec 12, 2005 | 11:19 PM
Instigater's Avatar
I would not worry too much about the "Check Engine" part of the diagnosis, because the key is on, without the engine running!
Old Dec 13, 2005 | 01:39 AM
itstillruns's Avatar
not sure if this will help but you have 2 spark plugs (2 cylinders) both are factory Champion plugs. Get rid of the Champions! I recently" got out" of wheeling with trucks and the same applys for ATVs (from experience). Champion plugs foul out and dont clean themselves. Polaris machines seem to foul easily, install NGK or other quality plugs in everything that you own that burns gas. Plugs are hard to get at (biggest complaint I have on Polaris side by side motors) One plug is on each side of the head. find plug wire and follow it down. BEFORE pulling wire off make sure the hole the plug fits into is clean. (nother flaw) use compressed air to blow area clean . you can handle it from there.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
