WHeel Spacers
Old Dec 20, 2005 | 09:58 AM
Playful1's Avatar
Default WHeel Spacers
I have an 02 500 HO sportman i have since put on 26" Mud Lights with 1 " wheel spacers,my problem is i purchased the wheel spacers used.One of the studs is over torqued and streached.I have been looking to find new ones but Kimpex or no one seems to know where to find these studs.I know they must be available,anyone know where???? 3/8X24 nf with the right spline and head???The company that makes them says we will sell you a new set of spacers [img]i/expressions/face-icon-small-sad.gif[/img] There is nothing wrong with them other than i would feel a bit safer if they were replaced as i like to drive my bike if you know what i mean.If any one knows where i can find some email me at ghawkins@nbnet.nb.ca
Old Dec 20, 2005 | 03:03 PM
2000scrammy's Avatar
Did you notice much of a difference when you put the wheel spacers on. Do you have better handling at all. Or can't you really tell.
Old Dec 20, 2005 | 06:01 PM
QBall's Avatar
Playful1
Post the name of the company who made the spacers if you will. It would be nice for the rest of us to know so that we could avoid doing business with jacklegs who won't provide you with a freakin stud, in order to force you to buy an new set of spacers.
There are a couple of things you can do.
1 Knock the stud out and take it to a local auto parts store, chances are they will be able to match it up to somthing in stock.
2 Failing that pull the spacer, knock the stud out and drill out the hole and replace the stud with a grade 8 nut and bolt. I have done this on a tractor and if it works on a 5 ton tractor, it'l do ya fine on your quad.
Regards
Q
Old Dec 20, 2005 | 06:35 PM
conig's Avatar
might be able to find a stud at an auto parts store or walmart im not possitive but I want to say I saw that size while searching for lug nuts for my honda.
Old Dec 20, 2005 | 07:21 PM
MaineMudder3's Avatar
Not to ask a dumb question but why did you put wheel spacers with 26" mud lights..they fit without them.
Old Dec 20, 2005 | 07:28 PM
Playful1's Avatar
Auto parts stores around here don't stock anything like it.Would like to have ones like original without modifing.Handles great tires are even with back tires.Seems alot more stable
Old Dec 20, 2005 | 07:42 PM
Playful1's Avatar
Mud lights i put on are wider than stock,26x10 and 26x12 they fit fine on stock wheels but the rub the tie rod end boots without spacers.
02 Sportman 500H0,26" Mudlights,K&N,DynoJet Kit,White Brothers xhaust,Dalton Clutch Kit.Reverse Override
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
