OLD SMOKEY
Old Dec 23, 2005 | 04:55 PM
redneckfromnb's Avatar
Default OLD SMOKEY
hi i got a 185 honda,it has a rebuilt motor and it still fouls up the plug.its not flooding or nothing.its like sootand it still smokes.i put in all new gaskets.just wondering what you guys think could be wrong.theres about 1 week on the rebuild,its taking 3 or more plugs to keep it running.
Old Dec 23, 2005 | 06:54 PM
DavidLT250S's Avatar
Default OLD SMOKEY
adjust the valves and maybe your running to rich or lean what color is the smoke?
Old Dec 23, 2005 | 07:45 PM
Default OLD SMOKEY
the smoke is a grayish black,as far as adjusting the valves i dont know what to set them at.any suggestions?
Old Dec 24, 2005 | 02:31 PM
Default OLD SMOKEY
well try to get a owners manual they should have the settings in it, my bike is also smoking like a b*tch but it need a new top end maybe the guy did the top end wrong?
Old Dec 24, 2005 | 04:50 PM
ThrashAndCrash's Avatar
Default OLD SMOKEY
Set the valves at .002in
If you had anything to do with this rebuild: What was your piston sidewall clearence, what were the ring end gaps on the rings? Were the valve seals replaced? Were the valve seats checked? I have NEVER, EVER fouled a plug on a 4stroke engine I rebuilt! Someone didn't do this rebuild correct!
Old Jan 1, 2006 | 05:38 AM
kart38's Avatar
Default OLD SMOKEY
Sounds like your in need of a needle/jet set for the carb. This is something we see a lot of at the motorcycle shop I work at. Almost all ATCs we get in need a new needle/jet set. This would be the needle in the center of the slide and the jet that it moves in and out of. When they wear they flow a ton more gas into the engine causing fouled plugs and dark smoke. For about $30 and 30min you will have a fine running three wheeler. There is a Moose kit available for the 185s, this is not as good as the Honda kit. We recently tried one, because they are about half the price, and it didn't work any better than the wore out Honda parts. Once new Honda parts were installed all was good.
If it was oil smoke it would be blueish white, not anything resembling black.
Jason
110cc loncin
1) Engine problems..
Feb 12, 2013 03:50 PM
claypipe007
Jun 13, 2012 05:29 AM
TJ 755
Feb 6, 2008 12:42 PM
maggiesboy
Oct 21, 2004 01:39 AM
