PROBLEM WITH HONDA 400 FOREMAN
Old Jan 4, 2006 | 01:52 PM
erno's Avatar
Default PROBLEM WITH HONDA 400 FOREMAN
I have transmission problem with 400 honda only 2WD active??????????????
Suggestions please
Old Jan 4, 2006 | 03:57 PM
redonthehead2's Avatar
erno:
The problem is likely the splines in the front propshaft are stripped out. Jack the front end off the ground and try to rotate the front tires. If they turn without the rear wheels turning you definately have a problem. Look to see what rotates and what doesn't - there is a connection that has failed.
Look at the left side of the engine down low and in front. there is a "cup" mounted on a shaft coming out of the engine. Inside that cup it is splined. Out of that cup there is a shaft running to the front diff. You probably need both shaft and cup. I did - been there, done that. Its a bitch but doable.
If this is it you might consider buying a warn 424 system. I believe it goes in to replace this shaft/cup?
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
