VDI Module (regular)...
Old Jan 17, 2006 | 02:41 PM
sandpit's Avatar
Default VDI Module (regular)...
What is the difference between a regular and Copperhead.I just got a regular module for my bike from another guy.It's new,in package.
Old Jan 18, 2006 | 02:52 PM
sandpit's Avatar
OK.
I've done alot of searching,and I've come to this???
Is the only difference that one you have to splice the wires,and the copperhead is just a plugin?
Old Jan 18, 2006 | 03:29 PM
CobraR6's Avatar
Well, the difference is simple. The regular modules that cost around 100 bucks, like VDI's, only work from 0-7mph. They take away the low end lag that the manufacturer puts in the machine. The Copperhead for instance is a CDI. This gives you more power throughout the entire power band, and not just low end. Dyna also makes a CDI module. The VDI copperhead is suppost to get more mid range and top end than the DYNA, but it is also more expensive. Moose makes a module that is plug and play, and it is 100 bucks. If you are just looking to get rid of the low end lag, this might be the way to go. Otherwise, I would save up some extra cash and get the VDI. Hope this helps.
Old Jan 23, 2006 | 02:39 AM
mentalmojave's Avatar
copperhead is msd(multi spark discharge) much better burn
Old Jan 23, 2006 | 03:01 PM
sandpit's Avatar
Thanks.
Can't wait to get it hooked up.
Old Jan 23, 2006 | 07:40 PM
brokebrute's Avatar
I had the module on my Brute 750 I was not impressed I could barely tell the differance between the switch beeing off or on, my buddies brute would still stomp me.
Old Jan 25, 2006 | 10:47 PM
Poindexter660r's Avatar
CobraR6 is close.
The best explanation is at www.velocitydevices.com.
The Copperhead is a fully programmable MSD that allows you to customize two different timing curves. You can also get rid of the factory redline rev limiter, reverse rev limiter, limp mode, and low rpm detune that the factory programs into the ignition system. You can add or take away any of these options on both timing curves.
So, you can program the first curve with factory timing (5 degrees), take away the rev limiter in reverse, and override limp mode. Then on the other curve you can set the timing at 11 degrees for 87 octaine and override all safety features. The curves can be non-linear as well. So you can add 11 degrees at lower rpms, then go to 12 degrees at 3500 rpms, then back to 10 at 7000 rpms to allow for the rate that the engine builds revs. You can set the curve every 50 rpms if you like. You have to have the programmer to do this. The software runs on a pc with a usb port.
There is another post out there somewhere that has vids of a BF beating an Outi 800 and the only mod on the BF is a Copperhead. That tells me it's good for about 10hp.
Old Jan 25, 2006 | 11:38 PM
CobraR6's Avatar
Originally posted by: Poindexter660r
CobraR6 is close.
Lol, you nailed it right on the head. I should have given this link too.--> Nyroc This site has ALOT of info on the copperhead, also it has the video you were talking about with the brute force, and the outy racing. I think you have to join to view it. Just join, then go to the Prairie forum, there you will find all the info you need on VDI's copperhead.
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Elkaholic
Sep 6, 2015 02:44 PM
ltrmc02
Jul 22, 2015 04:50 AM
