450R doesnt start?
Old Jan 17, 2006 | 06:03 PM
kevin724's Avatar
Default 450R doesnt start?
hello all, new to the board. A few questions for the more knowledgable ones out there.
I tried to start my 2005 450R earlier but it doesnt seem to start. I had the key in the on position, in neutral, cluth depressd, choke on, i even added more gas. It doesnt even sound like its going to turn over. I called the dealership where i bought it and they said i need to bring it in to get the carb cleaned out, he said it was filled with dirt but i dont think that could be in because i hardly rode the thing, only had it for 4 months. He also said after its been sitting around the alcohol evaporates from the gas and he said he guarantees that if i drain my gas out now it will be"**** yellow" instead of clear. Is there any other options i could try before bring it to the dealership? that is my last option.
thanks in advance!
Old Jan 17, 2006 | 09:22 PM
Sanman66's Avatar
Worth a shot, another thing to think about when mine is lean it has hell starting.
Old Jan 17, 2006 | 09:26 PM
White7's Avatar
Dumb question but,,you do have the on/ off switch on correct
other than that check spark,do you have spark?
Old Jan 18, 2006 | 05:54 AM
nadafam's Avatar
I know this is also a bad ?
but is the gas valve on.
Aslo if it has been sitting fouled plug?
Old Jan 18, 2006 | 10:45 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
The one time I have a very hard time starting my R, is after I have tipped it up on the grab bar (gas valve off, of course).
Old Feb 9, 2006 | 07:31 PM
kevin724's Avatar
ok, apparently I need to drain my gas and clean out the carbs. Can someone give me some light on where the gas drain is and how do i clean out the carbs? im fairly handy with cars but this is a first on a Quad. Any help would be great, thanks!
Old Feb 11, 2006 | 01:39 PM
JSsDS's Avatar
There is a screw at the bottom of the float bowl that is accessable with a screwdriver in the horizintal position. Put a clean light colored drain pan or glass under the hose and open the screw. The float bowl will drain and you wil be able to see if any dirt comes out.
Considering that you have 4 month old gas, I would strongly recommend that you drain the tank and add new fuel. This is easily done by removing the supply hose from the carb, open the gas valve and let it flow. Keep an eye on this gas in case there is dirt in the tank.
Old Feb 11, 2006 | 02:43 PM
yellow400exrider's Avatar
my 400ex wouldnt start the other day and i got a new spark plug and it started right after that so jus try a new plug
MikeyBoyesq
Nov 27, 2020 02:44 PM
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
dorene
Jun 5, 2015 05:25 PM
Hondaislife
May 28, 2015 01:43 PM
1000gade
May 27, 2015 12:37 PM
