Starting issues
Old Jan 19, 2006 | 09:31 AM
snowfreak's Avatar
Default Starting issues
I had a problem a few months ago with my 03 400. Here's the link:
http://forums.atvconnection.com/mess...&keyword1=2003
Well I had sometime yesterday to fix the gear selector and when I put it back together, it wouldn't start.
The problem is that I have no spark at the plug. What should I be checking next?
Could it be that I did somethng to the harness going to the stator? Does anyone know what the ohm readings should be for the stator?
It has a blue, white, yellow & green wires on 1 plug and 3 black wires on the other.
Any ideas cat gurus??
Thanks for any help
Old Jan 19, 2006 | 11:51 AM
CATSKINNER's Avatar
Sounds to me like your Neutral Safety Switch in the shifting linkage may be out of adjustment. Did you try pulling on the brake and starting it? If it starts with the brake applied, I would say you need an adjustment.
Good Luck
Old Jan 19, 2006 | 03:21 PM
Bear4570's Avatar
The neutral safety switch prevents the engine from cranking, not shut off the spark. Could you have blown a fuse somehow? First check all you fuses. If that's not it you probably got a wire either hooked up wrong or pinched. Take the selector back apart and try it.
Old Jan 19, 2006 | 03:37 PM
snowfreak's Avatar
Thanks for the suggetions, it does crank over just fine but does not have any spark at the plug.
Fuses all checked out fine, I tried reading out the wiring going back to the stator and I have
continuity on the blue/white but nothing on the green/yellow.
I ordered a service manual but until then I don't know what the readings should be.
Anybody have a idea on this.
Old Jan 20, 2006 | 04:12 PM
snowfreak's Avatar
Bear
I pulled everthing apart again and am going to check all the wiring back to the stator when I get to work tonite.
Any ideas on what it should read?
Thanks for your help
Old Jan 20, 2006 | 04:43 PM
Bear4570's Avatar
If the stator or any of the wires are open, it means there will be no spark.
Old Jan 25, 2006 | 03:55 PM
snowfreak's Avatar
Thanks for the help Bear!!!
Tore into it again and I think I found the problem, one of the wires had pulled out of a splice. Repaired it and it now
reads about 195 ohms.
Won't know for sure till later on in the week, waiting for the gasket to come in.
I'll let you know when I get it all back together.
snowfreak
Old Jan 27, 2006 | 10:37 PM
snowfreak's Avatar
The gasket came in and I put everything back together and it fired right up. Thanks again Bear for the help. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 28, 2006 | 12:22 AM
Bear4570's Avatar
Snow, You are very welcome.
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
BEEFKING69
Jun 17, 2015 12:38 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
