polaris starters
Old Jan 30, 2006 | 05:00 PM
ksbowhunter's Avatar
Default polaris starters
can anybody tell me how you get the starter out of a 300 exploers
Old Jan 30, 2006 | 05:09 PM
ncriderforks's Avatar
Remove the clutch cover, clutches, and inner clutch cover. This will get you to the starter on the back side. You will see the bolts that you will need to remove. Remove the pull rope cover. There are two 10mm head bolts around the starter drive that will have to be removed. Remove the 2 bolts and then pull the starter out from the clutch side. Make sure you disconnect the battery before you do this.
Old Jan 30, 2006 | 06:03 PM
can you remove it without taking the clutch out. i got a wrench on the top bolt
Reactant
Mar 30, 2022 02:08 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
tweeder
Jul 5, 2015 01:57 PM
