Grizzly headlight problems
I have a 2004 grizzly and the left headlight is really dim. They are aftermarket blue bulbs,
not sure which ones. Anybody have a clue? Is it a stator problem or the bulb itself?
THanks!
THanks!
You might want to be sure the ground wire to that bulb is good. Often a dim bulb is the result of a corroded ground wire. Less often the hot wire is the problem.
RedRancher
Oct 15, 2020 01:45 PM
