EPI pink spring installation pics
Old Feb 8, 2006 | 10:25 PM
shortyno11's Avatar
Default EPI pink spring installation pics
the spring
the spring
take the black cvt cover off. all bolts are 10mm
inside cvt
take off over drive cover bolts are 10mm, the center is 19mm and the threads are left handed on the center bolt, then take out the spring.
Stock V.S. Epi
install new spring
install spring
put the over drive cover back on and line up the 2 shims
2 shims on back of cover
put everything else back together and enjoy!
review coming soon
Old Feb 9, 2006 | 10:39 AM
2lman's Avatar
How long did it take for your idle adjuster to fall out? [img]i/expressions/face-icon-small-wink.gif[/img] I just noticed yesterday that the one on my KVF had fallen out as well.
Old Feb 9, 2006 | 08:07 PM
shortyno11's Avatar
it didnt fall out. i just pulled it outta the cvt vent tube. it attaches to it.
Old Feb 10, 2006 | 03:02 PM
LittleBill's Avatar
time to ask a dumb question, this is the first time i have a seen a quad belt system exposed, and noticed something different, my buddy has a 87 artic 650 snowmobile, and both of his pulleys???? move. one tightens up as the other opens up. it seems on this quad only 1 pulley changes gear ratio?
Old Feb 10, 2006 | 04:37 PM
BigReub's Avatar
Same thing here, Bill. The Primary (front) closes while the Secondary (rear) opens to change the ratio.
Old Feb 10, 2006 | 07:46 PM
shortyno11's Avatar
the pulley on the left closes.
Old Feb 11, 2006 | 12:46 AM
Plainsman's Avatar
I put my pink in tonight. So now black/pink. The downshift from about 12-14 is more aggressive, the disengagment is about 3mph. I also pulled the KEBC fork, I like the feeling of that gone.
I had a spacer behind my primary oem spring, so I left that in. I read in the manual the late A2 B2s had 1 spacer stock and 2 for high altitude. What have others done?
Old Feb 11, 2006 | 01:44 AM
shortyno11's Avatar
whats the KEBC fork thing?
Old Feb 11, 2006 | 11:09 AM
ajd187's Avatar
It's for engine braking on the utes. The KFX 700 doesn't have that.
Old Feb 11, 2006 | 02:54 PM
shortyno11's Avatar
o. ok.
fordfaithful21
Dec 7, 2015 05:52 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
black_thunder
Sep 7, 2015 01:24 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
