ROUGH SHIFTING ON MY RANCHER
Old Feb 11, 2006 | 07:12 PM
pseman's Avatar
Default ROUGH SHIFTING ON MY RANCHER
i am having some wierd things going on with my 03 rancher es. it is shifting real hard. it kinda feels like its gonna trow ya when you push the button. i was reading on the forum about adjusting the clutch once in a while. my rancher has 1200 miles on it. should i adjust the clutch? i havent had any blinking numbers and the es shifts, it just shifts darn hard.
thanks in advance
sean
Old Feb 11, 2006 | 07:30 PM
1988TRX250R's Avatar
Definetly adjust the clutch. I'll have to double check the service manual but I think the recommended service interval on clutch adjustment is every 600 miles, same as the oil change interval.
Old Feb 11, 2006 | 07:33 PM
Sorry, forgot to add that even a clutch that is WAY out of adjustment will not throw an ECM code.
Old Feb 12, 2006 | 01:32 PM
pseman's Avatar
do you have any idea how to adjust the clutch?
Old Feb 12, 2006 | 04:42 PM
pseman's Avatar
nevermind i figured it out
thanks for your help
sean
Old Feb 13, 2006 | 01:18 AM
quicksilver's Avatar
how does it work now?
My rancher shifts a little harsh at first like the first shift i do when i go out for a ride, then it's fine, i think it's because the clutch has to whip around in the oil for a bit to get lubricated to give you that smooth engagement.
but anyways, it's a good idea to crack out the tool kit and adjust it each weekend you go out or whatever. It's easier on the transmission and clutch parts.
Old Feb 13, 2006 | 06:19 PM
pseman's Avatar
it works much better now. seems like it shifts faster and smoother now.
thanks again for all the good info
sean
Old Feb 14, 2006 | 02:43 PM
LittleBill's Avatar
check your idle speed too, if its too high it will really slam when first going into gear
95wolv
Sep 27, 2024 12:00 PM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
Elkaholic
Sep 6, 2015 02:44 PM
