Raptor Service Manual discrepency
Old Feb 13, 2006 | 01:58 PM
GregP's Avatar
Default Raptor Service Manual discrepency
I came across a discrepency between the Raptor Service Manual and the Yamaha Parts Fiche. I replaced the stator in my '02 Raptor this weekend .... I am very conscientous about keeping track of parts that I have removed. As I was putting the Crankcase cover back on I was double checking everything with the Raptor Service Manual and noticed that I was missing a bearing for the starter gear & shaft #2. After searching the garage for an hour - I decided that somehow I had lost it (although I couldn't remember if I had seen one when I removed it to install the new stator) and went on-line to the Yamaha Parts Fiche to get the part # and see if any local Yamaha dealers had it in stock. But on the Yamaha Parts Fiche - they didn't list the bearing at all. I called a couple of Yamaha shops (service departments not open on Sundays) and ended up talking to a couple of parts guys - the only thing I got from them is that the Yamaha Parts Fiche is the only thing they go by. I decided to take a closer look at the starter gear & shaft# 2 and came to the conclusion that a there couldn't have been a bearing based on how tight is fits into the Crankcase cover. Has anyone else come across this?
Greg
Old Feb 13, 2006 | 06:01 PM
fizzak's Avatar
I am not sure if I'm talking about the same gear. When I did my LA oneway starter gear swap, I replaced the 2nd gear with a new factory piece as recommended by LA Designs. The new gear did NOT have space for the needle bearing set like the old gear. Instead it had a pressed-in-gear bronze bearing with oil galleys.
Old Feb 14, 2006 | 09:39 AM
GregP's Avatar
Old Feb 14, 2006 | 09:46 AM
GregP's Avatar
There is two gears - one of them had the bearing that you are referring to .... on mine it was the one with the shorter shaft - on the Yamaha Parts Fiche - the starter link - it shows it as parts #5, #6 and #7 (http://www.yamaha-motor.com/sport/parts/home.aspx) and they call it the "gear idler 1". On the same page they show parts #3 and #4 and call it "gear idler 2". If you notice there is no bearing for that gear. In the Raptor Service Manual they show a bearing for both gears?
Old Feb 14, 2006 | 11:30 AM
fizzak's Avatar
I see what you're talking about. Unfortunatly I cannot remember if that 3rd gear had bearings. I was going to check LA Designs page on replacing the gear but I cannot find the site. They HAD several photos of the gears installed without the cover.
Old Feb 14, 2006 | 12:35 PM
caliraptor's Avatar
01 Raptors had bearings in the big 52T gear and newer raptors use a brass bushing. Maybe the service manual you have is for an 01?
Old Feb 14, 2006 | 04:24 PM
fizzak's Avatar
He is talking about the other gear, one down from the 52T unit.
Old Feb 15, 2006 | 09:48 AM
GregP's Avatar
Well I put it back together and fired it up .... it didn't blow up :-) ..... so I am going to assume that the Service Manual is incorrect. The one thing I did notice is when putting that second gear back on is that it was a tight fit .... didn't look like there would be enough room for a bearing if there was one.
Old Feb 28, 2006 | 04:34 PM
maddog56's Avatar
Both the factory and clymer service manual are based upon the 01 model and some parts were carried over from manuals for the old xt660 bike. Expect things like that to pop up every once in a while. Heck, on some pages the picture of the head looks like the old four valve one.
Old Feb 28, 2006 | 05:30 PM
GregP's Avatar
Interesting - I had thought that when they released the '01 Raptor that it was a brand new motor. I didn't realize that it was derived from another bike. That's basically the same thing they did with the original Banshee motor.
MaasaiMomma
Mar 25, 2021 11:24 AM
neo27ny
May 14, 2018 12:19 PM
gogogo
Oct 15, 2015 05:40 PM
firsttimerider
Sep 3, 2015 08:24 PM
toonces
Aug 21, 2015 01:19 PM
