banshee smokes oil
Old Feb 13, 2006 | 09:25 PM
greenskin's Avatar
Default banshee smokes oil
i have a 98 banshee my problem is after a complete rebuild it tends to smoke littil more than average on the right side if your sitting on it i notice oil is sipping upon the head coming from under the plug plus it leaks oil down the flange were it connects off of the motor to the pipe . i had this problem before but it really was bad then and i put crank seals in it and that solved that but it still does this now any help would be much apperciated
Old Feb 14, 2006 | 06:47 AM
enFORCER's Avatar
Did you use a lot of lubricate when you put it together? If so you could have oil in your pipes.
Take them off and see if they have oil in them.
Old Feb 14, 2006 | 11:47 AM
DriverDoyle's Avatar
We just had the same prob with my buddies drag banshee....I still think it is your crank seal on the right side.....if you dont get them in there just right it will still suck oil out of your bottom end and couse a prob......
Old Feb 25, 2006 | 11:02 PM
400CatDriver's Avatar
We're having the same problem but on the left side. Seems like it pulls oil out of the transmission or something. Just got it back from A&S Racing and I don't think it's right yet.
Old Feb 25, 2006 | 11:44 PM
lenkner's Avatar
those crank seals can be trickey if your not used to doing that kinda of work it can be a pain in the ***, and some times you just get a weak seal try the seal and also clean out the pipes so when you start is again you wont have oil in or on the pipes good luck ride hard be safe
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
bvolks
Sep 13, 2015 12:57 PM
