banshee smokes oil
i have a 98 banshee my problem is after a complete rebuild it tends to smoke littil more than average on the right side if your sitting on it i notice oil is sipping upon the head coming from under the plug plus it leaks oil down the flange were it connects off of the motor to the pipe . i had this problem before but it really was bad then and i put crank seals in it and that solved that but it still does this now any help would be much apperciated
Originally posted by: DriverDoyle
We just had the same prob with my buddies drag banshee....I still think it is your crank seal on the right side.....if you dont get them in there just right it will still suck oil out of your bottom end and couse a prob......
those crank seals can be trickey if your not used to doing that kinda of work it can be a pain in the ***, and some times you just get a weak seal try the seal and also clean out the pipes so when you start is again you wont have oil in or on the pipes good luck ride hard be safe
jrooker6
Apr 23, 2016 07:36 PM
