first things first
Old Nov 12, 2000 | 01:31 AM
cb2000warrior's Avatar
i just bought a 2000 yamaha warrior and im thinking of doing some mods to it, once i get it broke in and was woundering what to do first. id like some suggestions on differnt rear tires the stock ones DO NOT like to slide at all almost tipped it on a gravvel road!!! if u say a new pipe and exaust please tell me what brand and that goes for every thing im new at this and need all the help i can get
thanks in advance
Old Nov 12, 2000 | 08:47 AM
KawasakiKid's Avatar
Well, it all depends on what type of riding you do and how much you want to spend?
-You can increase engine displacement (big bore / stroke kit)
-Cam(s)
-Higher compression
-K&N or UNI air filter
-White Bros, DG, Graydon Proline, and FMF are all well known exhaust manufacturers (take note if the pipe your looking at has a spark arrestor)
-Gearing (increase front sprocket size)
-Holeshot tires if you're looking for a great straight line tire with moderate slide (the wider they are the less they slide and vise versa)
-Carb and/or jetting (don't forget to re-jet after installing an aftermarket exhaust)
You may want to talk with Jeremy from Rage Performance. He's out of CA and an X-Pro. I've spoke with his several times regarding mods for my Tecate. They sell a lot of internal mods for ATV's (i.e. pistons, cams, big bore kits, cylinder work, etc.)
www.rageperformance.com
Hope this gives you a step in the right direction.
Old Nov 13, 2000 | 12:13 AM
Fourplay's Avatar
I recently installed a K&N jet kit, and a unifilter on my 2000 warrior and it was a noticable power increase. Next for me will be exhaust,I think a person would be happy with any good brand of pipe,FMF,White Bros.,Big Gun,etc... But stay away from the older (but cheaper$)designs like cobra,RCM,etc...If you want more power after that then you get into the motor(high compression piston,cam,porting,etc..But definitally do the intake & exhaust mods first. Also it,s a good idea to get a clamp-on style filter ,Pro design makes a kit for this,this way you can 1 - see with your own eyes that the filter is seated properly & 2 - run with the airbox lid off for more airflow.
Old May 28, 2001 | 10:18 PM
88warrior350's Avatar
I think holeshots are pretty good tires they give you increased traction but they also slide. I also think supertrapp IDS2 exhaust are good becasue they have the tunable diffuser discs on the inside. This means you can make it faster on top end( which also increases sound levels) or more power on low end(which decreases sound levels)depending on how many discs you have in it. It also means that the discs don't get muddy like other tunable pipes. The disc also has a spark arrester.
1988 Warrior,
Wiseco high compression piston and connecting rod, Bored .30 over, K&N Air filter, with flow filters in air box lid, k&N Jet kit, Supertrapp IDS2 Exhaust, holeshot front and rear mounted on douglas aluminum .190 rims, 15 tooth front sprocket, 40tooth rear, DG nerf bars, outerwears shockcovers, ceet gripper seat
Reactant
Mar 30, 2022 02:08 AM
COFatboy
May 2, 2020 12:06 AM
toonces
Oct 16, 2019 12:11 PM
ScopeZ_
Jul 28, 2015 01:44 AM
DeFox500
Jul 26, 2015 06:32 PM
