Rincon wheels on Rancher
Old Mar 13, 2006 | 12:53 AM
jbh's Avatar
jbh
Default Rincon wheels on Rancher
Does anyone know if the stock Rincon wheels will fit on a 2001 Rancher? I do not know if the front and rear offset is the same on the two machines.
Old Mar 14, 2006 | 07:49 PM
cluby's Avatar
No the rear wheels do not have the same offest, but I have seen where they have just turned them around so the valve steam is to the inside. I cann't say I would do this.
Old Mar 22, 2006 | 11:18 AM
atvcamper's Avatar
No, the off-sets are different, on the Rancher or Foremans the front are 2+5 and the back are 5+2.
That means that the back rims are "deeper than the front.
The Rincon off-sets are the same 2+5 & 2+5 because onf the independent rear suspension.
I've got a set on AMS Aluminum rims and AMS Blackwidow tires off of a Rincon, all
you need to do is buy the SPACER kit for the rear wheels to move them out 1" or 2' inches.
D0 a search for ATV Wheel spacers.
Old Mar 22, 2006 | 08:33 PM
crazy22's Avatar
no they will not fit because of there off set
Old Mar 23, 2006 | 08:21 AM
atvcamper's Avatar
Yes, they will fit. No the off sets are different.
You may notice a wider stance in the front but the rear wheels will be set in and not stick out as much. This is where the spacers for the rear come into play. They will put the rear wheels back out to where the original wheel base was.
Joe454
Nov 20, 2020 01:19 PM
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
