Problem with 2005 Wolverine
Old Mar 25, 2006 | 05:33 PM
spiggity's Avatar
Default Problem with 2005 Wolverine
I've had my 05 Wolverine for a year and haven't had a problem. Today I went out riding and my rearend started blowing the diff. oil out the breathing tube. Just wondering if anyone has had a problem like this or if someone might know why this is happening.
Thanks
Old Mar 25, 2006 | 11:53 PM
WolverineMan15666's Avatar
How cold was it that day? On cold days, my old '98 Wolverine would blow gear oil out the breather hose. i read where that is quite common on the old Wolverines. I don't know about the new ones.
Old Mar 26, 2006 | 12:20 PM
spiggity's Avatar
It was in the mid to upper 30's when I started to ride. I called my dealer when i got home they told me it was a common problem and there was a kit to fix it. But I looked all over the internet for such a kit and didn't find anything.
Hopefully this is the problem though. I wasn't able to ride for a couple of months, so this was the first time I rode it when it was cold outside.
Old Mar 26, 2006 | 12:38 PM
tdragano's Avatar
This is a common occurrence on the pre-2006 Wolverines. If you do a couple of searches (I'd do it for you, but I don't have time right now) you will find several suggestions on how to keep the oil from getting all over the place. This does seem to happen more on days when it is colder.
Check your rear end oil level and if it is OK, ride on. If you haven't changed it in awhile, you may as well change it while you have the tools out.
Old Mar 26, 2006 | 01:40 PM
spiggity's Avatar
Thanks for the feedback I will search around for ideas to fix it.
Old Mar 26, 2006 | 05:00 PM
Sparks89's Avatar
I've had the same thing usually after I have changed the gear oil, little air trying to excape (BURP)....but it does make a mess.
Good luck
CC
Old Mar 26, 2006 | 05:35 PM
wolverine68's Avatar
As I've written before, "T" off the vent lines with one running up to the existing position(to vent air) and run the other down towards the ground(the oil will dump out this line). This will keep the aibox area clear of diff fluid.
lightninboy
May 16, 2021 09:52 PM
Shifts
14
Jul 13, 2015 08:41 AM
tporath
Jul 11, 2015 12:31 PM
steveo612
Jul 11, 2015 08:35 AM
Shifts
Jul 3, 2015 07:59 AM
