300 TRX Starter???
Old Mar 28, 2006 | 04:36 PM
ILoveBowling's Avatar
Default 300 TRX Starter???
Hi all Ive got a question reguarding the starter on my honda trx 300. My son tried to start it up after it sat all winter and couldnt get it fired up, he told me it was cranking over just not starting, so I went out and checked it out and it cranked over once or twice and then the electrical system just went dead. So i charged the battery up and retried it with the same result. Ive got 12.5 volts on the battery and I even tried a brand new battery. But I still cant get it to crank over. All I can hear is the starter solenoid relay firing when the start button is pressed. Does it sound like the starter is shot and whats all involved in replacing it? Thanks for your help
Old Mar 28, 2006 | 04:40 PM
Also I should add that I did check out the starter solenoid and can get it to fire when connected to a 12v soucre, and I dont have continuity between the posts.
Old Mar 31, 2006 | 01:39 AM
1988TRX250R's Avatar
Use a test light to check voltage. Put the test light on the starter post, if it lights up your starter needs servicing. Disassemble and check the bruses, armature, etc. If the starter isn't getting voltage and the solenoid is clicking, the solenoid is the culprit.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
