help hith 05 eiger 4x4
Old Apr 1, 2006 | 06:29 PM
jnt3000's Avatar
Default help hith 05 eiger 4x4
I was out playing in the mud today and it starting acting up. The engine is running and sounds fine but when im in gear im hardly getting any power to the wheels. but it crawls in first gear (manual) Low and High and reverse i try to shift and its the same speed as if its not changing gears. Its not a engine problem it will run at full throttle but the wheels crawl /wont go. After playing with the shifter a couple of time it did kick in through all the gears but when i stop and go again it started again. any one a have any ideas? I thought a belt was slipping but someone told me if its manual it dosent have any belts.
I just took off my side panels and everything looked ok. the shaft moves in neutral fine but nothing when its in gear
Old Apr 1, 2006 | 07:02 PM
Dirtydude's Avatar
check the wet clutches
It's possible you may have fried them
Old Apr 1, 2006 | 07:25 PM
jnt3000's Avatar
where do i check them at?
Old Apr 1, 2006 | 07:39 PM
oper2nyst's Avatar
try stalling the engine against the brakes[common check in automobiles], if you can do so the clutches are most likely alright[if the clutches are bad the engine will increase rpm and most likely not stall] this should happen quickly if theyre allright and the engine should stall; dont do this for an extended period of time[more than 5-10 seconds] if your not mechanical the replacement should be left to a mechanic/ this is an internal engine component
neilbedwell
Nov 10, 2018 11:02 AM
panicmanic
Dec 15, 2015 01:58 AM
baysport
Jul 23, 2015 11:37 AM
HUNTFISHALASKA
Jun 5, 2002 06:11 PM
Fran
Sep 16, 2001 02:32 PM
