How to tell if a master cylinder is leaking air
On my 99 warrior that I just got the front calipers were missing when I got it so I just put the ones I got from ebay on. Anyway I have been bleeding for awile with no luck. Im just wondering if theres a good tricks to isolate were air is comming in at?
thanks
thanks
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
thanks
thanks
Are you tightening the bleeder all the way before you release the lever? Are you making sure the resivior is full before each attempt? Did you use brand new squish washers on the banjo bolts?
I was having a hard time bleeding my Harley's front brakes when I put stainless lines on it. I filled the master, and put the banjo fitting from the caliper in a bottle of brake fluid. I just kept pumping and tapping the line until I didn't see anymore air coming out of the master. Then, I slowly pulled in on the lever while my brother re-connected. It was being a real pain.
exmotocrosser
Sep 13, 2019 06:12 AM
