ATV clutch not engaging properly?
Old Apr 17, 2006 | 05:48 PM
rubberman's Avatar
Default ATV clutch not engaging properly?
I have a 2000 Kawasaki King Quad 300 4x4. The last time i used the atv was about a month ago for ice fishing and everything was fine. Since then i took it off the trailer and could not get the dang thing to shift properly. It would skip gears or not properly engage into a gear at all. Is my clutch shot i am wondering, or does it have a fluid problem? I was thinking there could be some moisture in the oil/clutch fluid resevoir from driving it through the snow/slush (possibly). I also left the hand brake engaged and locked when i stored it which shouldn't make a difference. Please let me know what you guys think. Thanks for the support.
Rubberman
Old Apr 20, 2006 | 08:39 PM
Kawi650's Avatar
ok now go to your machine. If it says Suzuki King quad it's a suzuki. I f you have a bayou the shifter is probably just bent in wards, if you bend it out it shouln't skip. you have a wet clutch so I don't think it's the clutch could be the gears but I don't think so because you would still have reverse. If you have a KVF300 you probably have oil in your clutches
Pahuntman
Sep 5, 2015 11:07 AM
ylomnstr
Sep 4, 2015 05:02 PM
cdstang
Aug 31, 2015 07:52 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
ghost civic
Jul 15, 2015 10:48 PM
