Dial-a-jet
I stumbled acrossed this when I was looking at paddles. Sounds like it would be worth a try.
Click here
Tell me what you think about it, or if you already have it, does it work??
Click here
I found some more info on this dial-a-jet. Check out the link on the left too that says U.F.O. That looks interesting too.
Click here
Click here
Alot of guys in the Banshee world use these with alot of sucess. Basically the idea is to jet to the leanest state you would need. Say you were to ride occasionaly at 10,000ft for instance. Then as you move down in altitude you use the DAJ to richen your mix. I will be running these on my shee. They say they also help with throttle response in the drag races due to the extra fuel supply.
