Dial-a-jet
Old Apr 19, 2006 | 01:09 PM
SW2steve77's Avatar
Default Dial-a-jet
I stumbled acrossed this when I was looking at paddles. Sounds like it would be worth a try.
Click here
Tell me what you think about it, or if you already have it, does it work??
Old Apr 19, 2006 | 01:45 PM
SW2steve77's Avatar
Default Dial-a-jet
I found some more info on this dial-a-jet. Check out the link on the left too that says U.F.O. That looks interesting too.
Click here
Old Apr 19, 2006 | 03:20 PM
DemonDS's Avatar
Default Dial-a-jet
Alot of guys in the Banshee world use these with alot of sucess. Basically the idea is to jet to the leanest state you would need. Say you were to ride occasionaly at 10,000ft for instance. Then as you move down in altitude you use the DAJ to richen your mix. I will be running these on my shee. They say they also help with throttle response in the drag races due to the extra fuel supply.
Old Apr 19, 2006 | 04:15 PM
NickDS650's Avatar
Default Dial-a-jet
I had the dial-a-jet at one point in time, worked pretty good with my stock carb, it was nice to just turn the dial one click like when it went from summer to winter for example.
Old Apr 19, 2006 | 05:42 PM
yjacket2001's Avatar
Default Dial-a-jet
DemonDS,
Good strategy for setting tune, instead of 'trying' to optimize dead center.
Thanks!!
STLyamwar
Jul 25, 2020 04:44 AM
jnisson
Jun 14, 2004 07:21 PM
joequad
May 15, 2004 01:39 PM
Vforcer
Aug 8, 2003 01:41 AM
Oxygen
Feb 24, 2003 09:14 PM
