Brute 650 Oil Capacity
Hi Guys,
I put 2 quarts in the Brute and the dipstick continually reads at the minimum amount on the checkered part. What gives? I do not want to overfill this thing, but having it on minimum bugs me too.
Help!
Help!
Hi Hayashi,
I screwed it in snug each time. I am wondering if I should put in the 2.05L called for on a dry engine. I shouldn't have to though. I think 2 quarts is more than sufficient. What do you think Hayashi? By the way, thanks for helping Kawi owners. You always seem real knowledgable on all things Kawi.
Bubba
Bubba
You measured corretly - screwing it in.
Capacity is about 2 liters which equals to about 2.7 U.S. quarts. Don't get units mixed up.
After adding oil, run the engine, wait 5 minutes, then measure.
Good Luck.
Good Luck.
Hayashi, thanks for the tip. I confused the units in my head. Kept going from quarts to liters. My mistake. I added about a 1/4th of a quart and the dipstick measures exactly halfway between L and H. Just goes to show, take you time even with simple maintenance stuff.
Thanks again Hayashi!
Your dealer is wrong. You definately need to screw it in all the way to get an accurate reading.
