Brute 650 Oil Capacity
Old Apr 20, 2006 | 06:40 PM
bubba123's Avatar
Default Brute 650 Oil Capacity
Hi Guys,
I put 2 quarts in the Brute and the dipstick continually reads at the minimum amount on the checkered part. What gives? I do not want to overfill this thing, but having it on minimum bugs me too.
Help!
Old Apr 20, 2006 | 06:56 PM
Hayashi's Avatar
When you were checking, did you screw in the dip stick or just rest it on the top?
Old Apr 20, 2006 | 06:59 PM
bubba123's Avatar
Hi Hayashi,
I screwed it in snug each time. I am wondering if I should put in the 2.05L called for on a dry engine. I shouldn't have to though. I think 2 quarts is more than sufficient. What do you think Hayashi? By the way, thanks for helping Kawi owners. You always seem real knowledgable on all things Kawi.
Bubba
Old Apr 20, 2006 | 07:06 PM
Hayashi's Avatar
You measured corretly - screwing it in.
Capacity is about 2 liters which equals to about 2.7 U.S. quarts. Don't get units mixed up.
After adding oil, run the engine, wait 5 minutes, then measure.
Good Luck.
Old Apr 20, 2006 | 07:28 PM
bubba123's Avatar
Hayashi, thanks for the tip. I confused the units in my head. Kept going from quarts to liters. My mistake. I added about a 1/4th of a quart and the dipstick measures exactly halfway between L and H. Just goes to show, take you time even with simple maintenance stuff.
Thanks again Hayashi!
Old Apr 20, 2006 | 07:31 PM
TCMan's Avatar
FYI...My Kawi dealer told me not to screw in all the way because it wouldn't be accurate. I checked the manual and it says to screw it in to check...who to believe?
Old Apr 20, 2006 | 07:56 PM
MadLT's Avatar
Your dealer is wrong. You definately need to screw it in all the way to get an accurate reading.
Old Apr 20, 2006 | 08:03 PM
Hayashi's Avatar
All current Kawi ATVs require the dip stick to screwn in when measuring. Honda is opposite I believe.
Old Apr 20, 2006 | 08:13 PM
Kawi650's Avatar
make sure the machine is on level ground
Pgbama11
Jan 16, 2016 08:19 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
