400ex problem need help
Old Apr 21, 2006 | 10:12 PM
madbowler's Avatar
Default 400ex problem need help
i have a 01 400ex. the problem i have is that the long oil filter cover bolt snapped off when i was trying to changer the oil. how do i fix this problem so that i can get it to hold oil and not worry about leaking. do i have to take the engine apart to get the part of the bolt out of the case or is there another way. any help would be very appreciated.
Old Apr 21, 2006 | 10:29 PM
TractorPacker's Avatar
Do you have a balloon?
Ouch, thats gonna be tuff. How much bolt came out? I doubt you will be able to drill and easy out, that small.
Old Apr 22, 2006 | 01:36 AM
madbowler's Avatar
the bolt came completely out but it only had 1 or 2 treads on it. i tried to use it but it wouldnt tighten down. not sure what to do
Old Apr 22, 2006 | 01:57 AM
bal3wolf's Avatar
sorta confused so you got the bolt out but the head broke off it if so try a atv shop and get another bolt.
Old Apr 22, 2006 | 04:33 PM
madbowler's Avatar
the part of the bolt that tightens down in the case to hold the oil cap closed it the part that broke off. that means that the threaded part is still in the case. remember this is the long bolt that i am talking about. putting a new one in there will not work because the threads are still in there so a new one wouldnt tighten down. i think that i will have to take the whole side of the engine off to get that part out then get a new bolt but i would like to know if there is a better way. can anyone help me
Old Apr 22, 2006 | 05:32 PM
okbeast's Avatar
Anyway you can drill the part of the bolt that's stuck out?
Old Apr 24, 2006 | 02:04 PM
HondaMan440ex's Avatar
You shouldn't have to tear the motor apart. and EZ out to get the rest of the bolt out. if that works you will prolly have to re-drill the hole and put a heli coil in there. I had to do that to all of my head bolts when i bored mine out. hope this helps.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
