250R Head gasket
Old Apr 25, 2006 | 06:21 PM
Jungle's Avatar
Default 250 Head gasket
Can any one tell me what is better I heard that an 89 cr 250 gasket is thinner and will give more comp. I also know that if you take the stock head gasket apart and use the thinner one that works too!!
But what is better??
Thanks
Old Apr 26, 2006 | 10:34 AM
pimpt250r's Avatar
Default 250R Head gasket
go with the 89 cr type i was told that would raise the comp between 5-12 lbs,,
spliting the gaskets the way u said , works but its a waste
Old Apr 26, 2006 | 10:33 PM
SFA's Avatar
SFA
I swapped my stock gasket in favor of the CR gasket in the hopes of more compression/power but I honestly didn't notice any difference at all.
Old Apr 27, 2006 | 11:09 PM
gassrx's Avatar
dont forget to put the big hole forward or it will over head the exhaust side
Old Apr 28, 2006 | 02:10 AM
86250rrider's Avatar
yeah ...what they said. trx=3piece, can take apart,atc=thinner than trx (all 3 pieces),cr250 very thin,best choice. my bike went from 180 to 195 going from trx to cr gasket. can be tricky to seal,had problems last time with gasket though.maybe i did have the hole facing wrong way DE DE DE!!!
Old Apr 29, 2006 | 01:50 AM
gassrx's Avatar
you could have me cut orings for $ 75
Old Apr 29, 2006 | 01:52 AM
gassrx's Avatar
put a long piece of solder in the spark plug hole against the wall and head, roll it over to make sure it has enough clearence
Old Apr 29, 2006 | 08:40 PM
Jungle's Avatar
Ok Thanks
I opted for the 3pc I am goin to take apart and use 1 of the thin ones this way i have 2 for price of one. hehehe
Now hopefully when I get it back together I can get this darn jetting figured out.......
Old Apr 30, 2006 | 12:30 AM
which carb u runnin on dat r ?
Old Apr 30, 2006 | 10:13 AM
Jungle's Avatar
Stock carb!! 42 pilot 140 main, stock needle, clip on 2, no lid on airbox
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
Minimod
Sep 10, 2015 09:20 PM
