LT80 oil on belt???
Old May 4, 2006 | 04:05 PM
mat050873's Avatar
Default LT80 oil on belt???
I just took the cover off the left side of my 1992 LT80 and there is black oil all over the belt and clutches. Obviously the belt is slipping. Any idea where the leak is? The oil injector does not appear to be leaking, so I am presuming that it is coming from the fan. Could it be a main seal on the crank? Has anyone else had the same problem?
Old May 4, 2006 | 07:02 PM
LT80's Avatar
LT80 Expert
Welcome to the ATV Connection forums. [img]i/expressions/face-icon-small-smile.gif[/img]
I suspect the gear box gasket (under the rear clutch).
Main seals suck in and the fan pulls air from the clutches so those won't be the culprit.
Old May 8, 2006 | 11:56 PM
mat050873's Avatar
I'm working on this '92 LT80 for a friend. The hose that goes from the fan housing to the clutch drive housing was missing. The exhaust flange was missing a fastener and seal, so it was leaking goop. Two stroke oil was all over the head, inside the fan housing, inside the belt drive cover, etc. The gearbox cover was sealed with RTV, rather than the OEM gasket. I believe that the shaft seal and gasket allowed some oil from the gearcase to leak, but the main problem was the oil from the exhaust and missing hose. Anyway, I cleaned everything up and have some new parts ordered. I don't have a service manual and I am in hopes you can help me with a few items: What is the proper torque for the cylinder head nuts, drive sheave nut and driven sheave nut? Thanks for your help.
Old May 9, 2006 | 03:40 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
There may not be any leak!!! THE BELT IS SUPPOSED TO BE BATHED IN OIL. It takes 80cc's, and there is a fill hole, and a weep hole (as I recall) on the housing in the back. Find an owners manual, if you can't figure out what I mean. I think it takes 10W30 4-stroke engine oil????
If your belt is slipping, it may just be normal wear.
I am always amazed at how many LT80 owners do not know this, and ride for years without ever changing that oil!
Old May 9, 2006 | 11:20 AM
LT80's Avatar
LT80 Expert
WTF??? Belt bathed in oil eh....NOT!!
No oil, no way, on a mini quad belt!
Old May 9, 2006 | 12:01 PM
Hymis's Avatar
WOW! I'm off to grease my belts! I also heard that greasing your brake rotors helps you stop faster.
Old May 10, 2006 | 10:10 AM
mat050873's Avatar
Jack,
Can you help me with the proper torque for the fasteners I mentioned in a previous reply?
Old May 10, 2006 | 10:14 AM
Red Rider
Seriously guys, I haven't ownedm (or even looked at) an LT in a dozen years, but you put oil in the hub at the rear, where as I recall, the belt goes around the rear pully??? So, what is this oil for then????
Like I said, most people don't know this and never change their oil, so I'm not surprised that nobody knows what I'm talking about!
Old May 10, 2006 | 02:13 PM
Quad4Fun's Avatar
That's funny.
Yes there is oil in the rear, for the gears.
Yes the belst goes around the rear clutch..
<u>NOT for the belt.</u> [img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img]
It must have been many many many years since you've seen or taken one apart...
You're right, we don't know what you are talking about, [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img] NO OIL ON THE BELT.........
LOL, don't worry though Recon, we all have temporary bouts of Cranial Rectitus, hehehehehe [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
LOL, I'm just giving ya a bad time Recon, it's all good, just funny [img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old May 10, 2006 | 02:25 PM
Quad4Fun's Avatar
Originally posted by: mat050873 I don't have a service manual and I am in hopes you can help me with a few items: What is the proper torque for the cylinder head nuts, drive sheave nut and driven sheave nut? Thanks for your help.
Here's some torque specs I've got:
cylinder head nuts = 6.0 to 8.5 lb-ft
Spark plug = 14.5 - 18
Exhaust pipe nut = 6 - 8.5
Magneto rotor nut = 25.5 - 31
Fixed drive face nut = 29 - 43.5
Clutch drum mounting nut = 29 - 43.5
Crankcase bolt = 6 - 8.5
Gear box magneto bolt = 6 - 8.5
Good Luck
