2005 Honda 400ex Electrical Problem help :D
Old May 7, 2006 | 03:18 AM
schwinn36's Avatar
Default 2005 Honda 400ex Electrical Problem help :D
I apoligized in advance for the stupid question...
I moved the ingnition switch and neutral/reverse lights so I could install new handle bars. I ended up cutting the ingition wires and spliced them back together. Now nothing is working, did I mess something up badly when I cut the ignition wires?
Thanks
JG
Old May 7, 2006 | 10:22 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
You didn't put a switch of any kind back in?
The 400ex has a battery so you need a switch of some kind.
Also I don't believ it is as easy as splicing the wires together. Makes a difference whether the key switch opens or closes a ciruit when you turn it on.
Old May 7, 2006 | 03:43 PM
fixitman69's Avatar
if you just cut the wires, you probably blew the fuse too
Old May 7, 2006 | 06:04 PM
schwinn36's Avatar
yes I put the ingition key switch back in, I just moved it to a different location, I'll check the fuses next and see if they are in good condition.
Old May 7, 2006 | 06:32 PM
schwinn36's Avatar
well I checked the fuse and, yup it was blown. Thanks for the help guys, and I think I just embarrassed myself with this question [img]i/expressions/face-icon-small-happy.gif[/img]
Old May 7, 2006 | 07:18 PM
squeege's Avatar
Why would you go cutting wires on a new quad for a set of handlebars? LOL
Old May 7, 2006 | 08:02 PM
schwinn36's Avatar
well I didnt like the look of the stock handle bars and I had purchased Tag T2 handle bars. The Ignition key switch, reverse light, and neutral light all had to be moved berfore installing them. Everything worked well, besides the fact that I blew the fuse.
Old May 7, 2006 | 11:37 PM
fixitman69's Avatar
schwinn, remember, 90% of the time you can trace the wires from your ignition switch and simply unplug them rather than cutting wires. when you are doing mods, spend a little time and save yourself a lot of time. glad I could help you out.
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
DTroyer01
Jul 3, 2015 07:34 AM
lovinhonda
Jan 25, 2000 09:17 PM
roktoy
Aug 25, 1999 04:37 PM
