90cc 2 stroke hard start when warm
Old May 8, 2006 | 10:36 PM
Will67's Avatar
Default 90cc 2 stroke hard start when warm
90cc two stroke in a GPX Raider starts great and runs good when cold....but shut it down and try to restart while its warm and you have to give it some throttle to get it to start....it runs rough then...but smooths out and is fine.
Where do I start? What do I do? I'm not real carb literate...but I follow instructions well...*L*
Thanks in advance.
Old May 9, 2006 | 12:06 AM
sssduane's Avatar
How old is the bike? Hard riden, sand, dirt etc............
Old May 9, 2006 | 01:01 AM
oldyeller's Avatar
Sounds like it could be running a tad rich.I'm not familiar with that machine but if it has a air/fuel mixture adjusting screw on the carb you might try turning that a little one way or the other to see if that will help.It's always a good idea before you start doing any adjustments to turn the screw in until it stops and remember how many turns it took to turn it in so you can always put it back to the stock setting if you need to.. If the bike has an electric choke that could also be the problem.
Old May 9, 2006 | 01:57 AM
Fastestdad's Avatar
Oldyeller aint lyin. Turn the air screw in to richen and out to lean it out.
Old May 9, 2006 | 08:43 AM
Will67's Avatar
The bike is about a year old now, ridden very little, and always just here around the yard so far. It has a Mikuni M2A carb. I played with the air/fuel mixture screw a little, turning it out, but didn't seem to help. Is there a "ballpark" area from all the way in that these typically run at? And, can I hurt anything seriously by leaning it out too much?
Old May 9, 2006 | 11:10 AM
sssduane's Avatar
Check the choke also, if its electric might want to try unplugging it when its warmed up to see if that helps.
Old May 9, 2006 | 11:23 AM
LT80's Avatar
LT80 Expert
I'd start with a good carb cleaning. [img]i/expressions/face-icon-small-smile.gif[/img]
Remove it. Remove the bowl. Remove the jets and clean/blow out thoroughly.
Old May 14, 2006 | 08:30 PM
Will67's Avatar
Ahhh.....had a lil time to play with the quad today.....I always wondered if the manual choke was hooked up or not....and it was NOT. The cable end wasn't seated firmly into the brass fitting on the choke...so the choke was actually stuck in one place all of the time! I seated it down in the brass fitting, crimped it with a pliers and done!!! Works great now. Thanks for the help guys.
MikeyBoyesq
Nov 27, 2020 02:44 PM
chinkapin
Jul 14, 2016 06:58 AM
Jbird4681
Jun 9, 2015 01:59 AM
1000gade
May 27, 2015 12:37 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
