my lt50 wont start?!?!?!
Old May 11, 2006 | 09:46 AM
lt50lover's Avatar
Default my lt50 wont start?!?!?!
hi, i was wondering if anyone could help me out? my lt50 wont start! the fuel is going into the carb but not getting any further? i was wondering if anyone else has experienced the same problem? or if any one has a labelled diagram/picture of the inside of the carb or any advice on what to try? any help would be great. thanx.
Old May 11, 2006 | 11:24 AM
maggiesboy's Avatar
"One Wheel Short"
if you turn the petcock to the prime position, and loosen the bowl drain bolt, does fuel drain out? If it won't flow out of the drain, your float valve (needle) might be stuck. How long has it been since your fiddy has ran?
How old is your fiddy?
Old May 11, 2006 | 11:29 AM
lt50lover's Avatar
i have had the carb apart and the float doesnt seem to be stuck, which bit is the petcock? i have also checked the jets and none of them are blocked, when i first disconnected the carb fuel ran out of the bottom.?
Old May 11, 2006 | 11:31 AM
lt50lover's Avatar
oh and i forgot to mention that it ran about 2 hours before this happened as i was riding and the chain somehow came off so i took it home and put it back on started her up and she was running for about 5 seconds then cut out?
Old May 11, 2006 | 11:56 AM
maggiesboy's Avatar
"One Wheel Short"
the petcock is the fuel valve attached to the fuel tank on the left side. if you had the carb apart, did you get the float installed correctly. This would be very important as far as fuel flow control. What made you tear into the carb at that point?
Did you look at the spark bolt, is it possibly fouled? It should be a dry cinnamon colored BP4HS NGK. do you have spark at the plug?
Old May 11, 2006 | 12:12 PM
lt50lover's Avatar
well when it wouldnt start after numerous attempts and i had checked the spark plug(it is the correct plug and has a brilliant spark), the carb seemed like a good place to start. i thought that there might be a blockage somewhere in the carb. it turned out that the jet (i think this is the main jet) from what i can make out takes the fuel through to the top part of the carb (i might be wrong but i am trying to explain as best i can) did have something in it because i blew through it and a bit of dirt or something flew out. but when i put the carb back together it seemed to make no difference so i am not sure what to do next.
Old May 11, 2006 | 12:16 PM
lt50lover's Avatar
i just loosened the drainage bolt and fuel poured out.
Old Sep 1, 2006 | 01:45 AM
scooter0946's Avatar
the one i have the kids hit the side of carb and it was barely at a angle and it didnt run i tride everything then i noticed it so see if it at a angle just pull it back up and try it
MikeyBoyesq
Nov 27, 2020 02:44 PM
merryman
Jun 27, 2015 03:31 AM
sut3000
Jun 26, 2015 05:54 AM
sut3000
Jun 25, 2015 02:00 PM
1000gade
May 27, 2015 12:37 PM
