04 450R- any known problems?
Old May 14, 2006 | 12:27 PM
TheCommonMan's Avatar
Default 04 450R- any known problems?
Hi-I am looking at getting a mint 04 450R with alot of extra's (pipe,nerfs,bumpers,etc..) and was wondering if there was any known problems with it like motor,frame, clutch, etc.... Also has anyone put one of those goki electric start kits on and how well do they work,look, install? Thanks for the help!
Old May 15, 2006 | 02:37 AM
TractorPacker's Avatar
Do you have a balloon?
The only problem I have with my 04 450r, is a blown knee. I can't start it till like September or when ever the doctor says its OK.
Really though, they seem to be free of typical problems. I have heard of something breaking on one, and something breaking on another. They don't have a "plague" like some models seem to adopt.
Old May 15, 2006 | 10:48 AM
96lapiscoupe's Avatar
Check the upper frame rail below the gas tank and right by the motor mounts for cracks. That's the most common place for the frame to fail if it's been ridden hard.
Old May 15, 2006 | 02:25 PM
twentycharacters's Avatar
the only mechanical problem that have been reported repeatedly is minor- that stupid heat shield on the pipe that vibrates the hex-head bolts out. i lost one the other day for the first time since i had the thing. however, its nothing that lock-tite wont cure... i dont know if honda corrected this after the 04 year or not. seems like they would have.
i could go into the problems with the handling but you are not asking that so i wont bother...
as far as the goki, they have been around ever since i can remember. i dont think they make crap but i dont think its top of the line either. their kit was installed step by step in a recent issue of dirtwheels on a 450R. it didnt look that bad but it doest look a little bulky (its a big starter) and sticks up and about a 45-60 degreee angle on the side of the engine. the kit has everything you need inc engine side cover and increases the oil capacity and utilizes a spin-on type oil filter instead of the "internal" type honda uses. it retails for $599 but you can prob get it cheaper than that. it has no effect on the kickstarter- which is a plus - so it can be used as a backup.
the thing that i would change if i got it would be the starter button that comes with the kit- looks cheesy. id get a cluster off of a 06 450r and wire it into that for a cleaner look.
other than that it may be worth looking into. if you convert on with all honda parts it will cost ALLOT and require another wiring harness. go to gokis website and/or get the issue of the dirtwheels where they installed and tested it. i think it was the same issue they tested the new LTR450R by itself (not the shootout with the other 450's).
Old May 18, 2006 | 10:14 PM
Thanks for the info fellas. Tractorpacker I know how you feel I used to have a 350X and you needed some muscle to kick that som bitch over!!!!!!
Old May 18, 2006 | 10:48 PM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
The only problem I've had is that I got addicted to it and want to ride all the time!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
