98' Foreman suspension problems
We have a foreman 450 that in the rear end, the left side of the rack seems to slope down a little bit, and the fender alone the side is bulged out from not sitting like it should. It cant hold as much weight anymore right now either. If someone else sits on that side of the fourwheeler, or if you go over a bump, sometimes the tire will rub on the fender. The axle and everything seems normal and isnt bent or broken. I am wondering if maybe the shock went out on that one side maybe?!?!? idk.. Any suggestions or thoughts appreciated. Thanks
This machine has two shocks, right??? Pull them off and swtich sides, and see if that transfers the problem to the other side.
As old as this machine is, it is quite likely you need replacement shocks.
TLC
Jul 11, 2015 02:28 AM
