problems with 2000 350 warrior
Old May 15, 2006 | 06:33 PM
primopro's Avatar
Default problems with 2000 350 warrior
The quad will rev up fine while it is at rest but if you take off and put a load on it the bike cuts out and back fires at about half throttle. I have went threw everything that I can think of that can cause this and nothing had fixed it. Need help! I took a carb of another warrior that was running fine and put it on mine and that did not fix it, I put a new cdi box on and nothing, adjusted the valves, put a new stator on it and messed with the parking brake switch. I also took every connection on the bike apart and cleaned the plugs very well. Two new spark plugs, a battery and know I have no idea of what to do. After all that I took it to a dealer and they were of no help.
Old May 15, 2006 | 06:53 PM
foxrider24's Avatar
try undoing the airbox from the carb and see if that helps b/c on my quad it was doing the same thing and i undid it from the carb and it runs great so i just got a clamp on
Old May 15, 2006 | 07:46 PM
bberck's Avatar
Inspect the boot that connects the carb to the motor. They sometimes get a tear in them letting in Air which will cause that. Take it off the quad and kind of bend it around to see. If does there like $50 from a dealer. My parents old Big Bear 350 did the same thing and the boot had a tear in the bottom of it you couldnt see.
Old May 15, 2006 | 08:29 PM
recon99's Avatar
Definitely check the intake manifold, it's a weak link on the warrior. Also, if you haven't tried it yet, maybe check the valve adjustment. A valve adjusted wrong can cause all kinds of erratic problems.
Old May 15, 2006 | 09:37 PM
drac1's Avatar
try your park brake leaver it might be stuck on it was on my friends wolvey back fire and stuff try it .it has a rev limiter on it i think like the wolverines
Old May 17, 2006 | 08:45 PM
foxrider24's Avatar
well primopro did you figure anything out?
Reactant
Mar 30, 2022 02:08 AM
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
