POLARIS Sportsman 500, 600, 700, 800 LIFT KIT #XTP800
Old May 18, 2006 | 10:55 AM
SPYDEY4's Avatar
Default POLARIS Sportsman 500, 600, 700, 800 LIFT KIT #XTP800
What do you guys think about the available lift kits on ebay for the New Sportsman? It is a 2 inch kit.
Right from the ebay auction:
Xtreme Products’ Polaris lift system is loaded with features. The front lift uses CNC machined aluminum spacers that are designed to prevent coil misalignment and prevent the coils from rubbing or binding on the struts. The system comes with a “strut spacer” to make setup simple.
The Sportsman 600, 700, and 800 models use this CNC machine spacer kit on the front suspension, but utilize precision brackets to lift the rear eliminating the need to change out the coil springs. This quick and easy installation greatly increases ride height and quality as well as increasing the payload capacity.
Combine this lift with a set of larger, more aggressive tires and wheels for the ultimate in off-road performance. The increased ground height, fender clearance, payload capacity, and handling improvement will make you glad you took your Polaris ATV to the Xtreme.
All of Xtreme Products' lift kits are built to exact specifications and designed with the bike's handling and performance in mind. Installation is simple with common hand tools. The asking price is $122 +7 s/h
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Gtsordo
Jul 13, 2015 10:38 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
