best trail riding pipe????
Old May 20, 2006 | 12:20 AM
flux's Avatar
Default best trail riding pipe????
any of you trail omly guys... 96db national forest law.... looking for low to mid range power,
with a tm 45 carb , ported intake , twin air power flow kit, 15 tooth sprocket, heavy duty cluch springs....
anything else????? oh ive read on here that you guys are geting more hp with the air box lid on....
is this true????????
Old May 20, 2006 | 10:05 AM
duneittilludie's Avatar
The stock pipe with a ODP disced end cap works well for trails.I assume that you already know that you cant have both a good top end pipe (and) a good low end one but the disced end cap is a good compromise.With a disced end cap or a similar pipe with discs you can add discs for more flow and top end performance or you can remove discs for reduced noise and increased low end performance. The nice thing about a pipe or end cap with discs is that you have a choice and to some extent some tunability that you dont get without discs.If your carb is sensitive to slight changes like adding or removing discs on a pipe you can add or remove the air box lid to accomodate flow changes to a degree.
Old May 20, 2006 | 11:56 AM
DSNUT's Avatar
Any pipe that is a bottom to midrange pipe will lose much of that lower end power when you remove discs or install the quiet core.
My old LTE system was sound checked with the quiet cores at 95 db. It was only 98 db without the core. The cop told me he didn't start handing out tickets until you come in at about 102. So I left the cores out. The LTE on my DS had great bottom end.
The other pipe that had massive bottom end was the Yosh RS-3. It was louder than the LTE. The quiet core would be a MUST if you were worried about db levels.
Old May 20, 2006 | 12:19 PM
rfwlll's Avatar
Flux. I run the hmf sport pipe and I noticed quite abit of power increase from the stock pipe. For what I have done to my quad which is not much it runs really strong. RUSS
Old May 20, 2006 | 12:25 PM
FatHolly's Avatar
Russ, I run the HMF too but don't you think it would be alittle loud for the 96db he needs... I've never had mine checked as I ride almost entirley Buttercup/Glamis so there is no worry about sound... but when I let friends ride my bike they take off and it is pretty freakin loud. Just a thought.
Old May 20, 2006 | 12:57 PM
rfwlll's Avatar
The hmf is loud, but with a core it is quieter right. lol I need to get one of those cores. I hav'nt had to worry about the db's yet. I was just figuring that since the hmf is a great pipe for the price, that would be the way to go. Around here there is laws on sound too, but they usually don't mess with ya if your riding carefull and not being an idiot. It was just my opinion. Good luck with what you choose. But I would say the lte are super cool and if I was'nt goin for a engine conversion I would bid on those lte's on ebay right now.
Old May 20, 2006 | 01:29 PM
JMAC650's Avatar
I run the FMF power core 4 with the quiet core insert. I brought a drill with me and drilled holes in the quiet core until it was 96db's. Stock with the quiet core it was 93db's. It works really well.
Frisky2050
Apr 9, 2020 11:19 AM
buckshit
Sep 24, 2015 08:49 PM
sara durrant
Jul 6, 2015 05:32 PM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
