BF 750 Problem... need advice
Old May 21, 2006 | 12:16 AM
ProXJC's Avatar
Default BF 750 Problem... need advice
Did some riding today in very deep water. The machine took some in and shut down. Would not turn over, pulled plugs hit start till no more miosture was present, then drained carbs. Oil was white from water, so I changed the oil. The only engine oil I could find was 10w40 klotz synthetic motorcycle oil, so I used it. Would this harm the engine? I appeared to run fine.
Then I hit some more deep water and the motor took in more water. Pulled plugs drained carbs. Engine oil was still white in color. I ran the machine for about 4 more miles when it shut down and blow white smoke (oil) out the exhaust. It started back up but still blew smoke. Got home and it seemed to run alright while driving it in the garage, the smoke out the exhaust was slowly going away.
What would have caused the white smoke and the stalling?? Did I bust a ring or valve seal??? If so why is the smoke slowly going away??
Any advice would be great.
THanks
Old May 21, 2006 | 01:18 AM
bruteforcebob's Avatar
sounds like too much water in the motor and it puked back into the airbox which would cause the smoke (hopefully its not rings or anything) go buy a gallon of marvel mystery oil and rotate back and forth between marvel and regular oil rinsing out your filter with diesel. repeat untill oil is clean then put a new filter a little marvel mystery oil and then fill with oil. ride it for an hour or 2 then change with a new filter one more time and run straight oil. in the condition you were talking about any oil will work. I use quakerstate 4x4 full synthetic in my motor.
Old May 21, 2006 | 02:42 AM
MadLT's Avatar
Make sure you don't neglect the differentials. They tend to take in water and if you don't make an effort to clean them out the fluids may not get changed out before a problem arises.
Old May 21, 2006 | 08:12 PM
v2rider's Avatar
You only changed the oil once??? If you took in water, you need to get it all out! It takes on average about 5 oil changes to do this. You literally need to change the oil, run it for a couple minutes, change the oil, run it a couple minutes, change the oil.................. As for the diff, i run water all the time, the diffs are sealed up very well on newer quads, otherwise, you would have to change the fluid every time you rode!!! If you go on a trip and dont encounter water, your doing something wrong. Ive changed mine once, and that was just to switch it to Amsoil synthetic gear oil, and ive checked it about every 150 miles, and no signs of water. And trust me, i LOOK for water to go through! But MadLt is correct, you should at least check to make sure periodically to avoid future problems.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
