sticking blaster throtle
Old Nov 22, 2000 | 07:17 PM
Blaster91's Avatar
I have a new throtle cable and it works fine. But when it got could and snowed outside, it started to stick at about 1/4 throtle.That happens when i keep the gas wide open and then let go. I need help, thanks.
Old Nov 22, 2000 | 10:47 PM
Fourplay's Avatar
Find out where it is sticking. unhook the cable from the throttle and push the throttle , it should snap right back.(twist throttles usually aren't spring loaded, so they should just turn forward & backward very easily) If that's OK then remove the cable and check that it moves back & forth easily. If that's OK then it's your carb, unscrew the top and check that the slide moves up and down easily.whichever three of these is the problem it,s probably due to water in them(freezes and sticks the part) or dirt/rust/gunk making it stick. You mentioned that you installed a new cable,.. is it routed correctly? If not when you turn your bars it may be getting pinched and causing the cable to hang up. Check for that first. Good luck.
Ahtatu
Sep 28, 2015 12:14 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
