cylinder porting
Old May 29, 2006 | 01:31 PM
jjjbob's Avatar
Default cylinder porting
if i get the cylinder ported on my trailblazer 250, will i have to use use racing fuel (100 octane)
Old May 29, 2006 | 01:49 PM
Silversteinfan's Avatar
you shouldnt have too unless youve got a motor that requires it.
Old May 29, 2006 | 01:52 PM
XSIVPWR's Avatar
Only if you raise the compression.
Old May 29, 2006 | 03:13 PM
16polaris's Avatar
You can get a trail port, and have the head shaved for a little more compression and you should be ok.
Old May 29, 2006 | 09:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
a mild port is basicaly for better fuel transfer to the cyclinder so the same octane would be fine.
Old May 30, 2006 | 01:54 AM
Polaris500HO4x4's Avatar
anything over 10:1 compression ration u need race fuel
Old May 30, 2006 | 04:20 AM
DSNUT's Avatar
Where did you learn that?
Did you know that Yamaha YFZ450's come from the factory with 11.4:1 compression and Yamaha recommends 93 octane Premium pump gas?
I would use premium up through 11:1, 50/50 premium and 110 racegas or 100 octane racegas at 12:1 and straight 110 on 13:1.[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 30, 2006 | 05:11 AM
duneaholic's Avatar
I run 12:1 in my race mod and use premium pump gas.
Old May 30, 2006 | 10:32 AM
scramblered's Avatar
there a lot of talks with 2 stroke when it come to head ratio,i've seen several highly modified sled puting
over 250 hp with race porting running on pump gas,they say they run best with,i do prefer polaris 110 octane
gas for any aftermarket heads tough and for all my 2 smoke,,the klotz race gas is just plain better,generally you must run 92 octane in
a 12.1 ratio and 104 octane at least on 14.1 ratio.the power of the ignition output really does a differences while using such
race gas,you can have race porting and still using stock heads and advanced squish angle,but you won't
have the better cooling capacities/durability the HPD or HOT SEAT heads offer.
Old May 31, 2006 | 02:29 AM
i actually ment higher octane... i was reading the thread about about race fuel and it was running through my mind at the time
Dewhound
Apr 20, 2017 02:25 PM
franklyme
Oct 21, 2016 07:18 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
