Primary clutch cracks ? heelclicker
Old Jun 3, 2006 | 07:59 AM
casual's Avatar
Default Primary clutch cracks ? heelclicker
Anyone seen any 1/4 inch cracks in their clutch after installing heelclicker kit? 700sp,cam, dual exhaust, 38 carb about 600 miles and 2 belts.
Old Jun 3, 2006 | 02:20 PM
SPORTSMAN70003's Avatar
Are you using low when you should? Cracks are caused by heat and if the belt slips that causes heat. Also I sent you a pm.
Old Jun 3, 2006 | 09:37 PM
casual's Avatar
Sportsman70003 what changes if any using the 800 primary? I think the bearing in the secondary needs to be changed, it might be adding excessive heat, I really dont use low gear only when towing or working which is not very often. I also have a bad habit of doing holeshots rather frequently. Thank you for your advice.
Old Jun 3, 2006 | 11:28 PM
With the 800 primary its like you are starting out in a lower gear and gives a better holeshot. One of the best mods I have done.
Old Jun 4, 2006 | 08:18 AM
casual's Avatar
Sportsman70003 Just ordered a 800 primary, Thank you again for your responses. Ordered from Surdyke Polaris they are always lowest prices I have found other than E-Bay.
Old Jun 4, 2006 | 09:03 AM
casual's Avatar
Sportsman70003 do you have an 05 or 06 primary I see the part #s are differant? Thanks Casual.
Old Jun 4, 2006 | 09:44 AM
docholiday's Avatar
I guess maybe you should start at your Service Shop Manual under Periodic Maintenance Chart. Their you will find that "every 1000 miles" you should be checking the bushings not only in your Primary Clutch but also in your Secondary clutch as well. For some reason Nobody seems to know of this and "how Important" it is to check theses bushings. If not maintained on a regular bases and Most Important the 1 behind the Spider on your Primary clutch. You could be sitting on a Bomb. "It has Nothing to do with any clucth kit". What it has to do with is people Maintaning their Clutches. Your movable sheave on your Primary Clutch, the one that moves back and forth has a bushing pressed in it witch should be Silver in Color and is 1/8 of a inch in thickness. If it is Brass in color than it should be replaced. This bushing behind the spider "when worn causes over heating and crackes" on your sheaves. Left untouched... your clutch could gernade and come right through your side cover. This includes All polaris models "With or "without" Any clutch kit. If you want reliablity it is a must that we as ATV 'ers educate each other on the importance of our machines to get the most reliability and performance just by simple Periodic Maintanance. Some folks say "Well I have 1500, 1800, 2000 miles on my machine and haven't touched my clutch"... Well Good Luck when you are picking clutch parts out of Leg...Hopefully you will be by a Hospital..Not 25 miles in on a trail. Check your Bushings.. it just might save your life and in return have the most reliable performance you can get out of your machine.
Old Jun 4, 2006 | 10:48 AM
casual's Avatar
Docholiday: GREAT INFO! I am printing your response. Thank You Casual
Old Jun 4, 2006 | 11:36 AM
I have the 05 800 primary. I have looked at the 06 800 primary and it looks to have the same parts in it but has a different part number.
Old Jun 4, 2006 | 03:07 PM
casual's Avatar
Sportsman70003 Thanks for the info, I ordered the 05 clutch then found the 06 had the differant #.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
