Sportsman 500 Help
Old Jun 7, 2006 | 04:28 PM
Predator72's Avatar
Default Sportsman 500 Help
I have a 98 sportsman 500 that wont start. It's getting gas, but no spark at the plug. It does get a tiny spark when I release the starter button. Would this be the coil, or something else? Thanks
Old Jun 8, 2006 | 03:38 PM
Predator72's Avatar
Any help would really be appreciated. Thanks
Old Jun 8, 2006 | 05:44 PM
Freedom500's Avatar
The ignition system works like a lawn mower. It is grounded to turn it off; no power from the battery is needed to get a spark. I would first try unhooking the kill wire on the CDI box. On a 02 Sportsman the kill wire is Black and the CDI box is under the hood.
Old Jun 8, 2006 | 05:46 PM
Predator72's Avatar
I'll try that, thank you.
Old Jun 8, 2006 | 08:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
he said he was getting a little spark when he let off the starter so i dont think there is a kill switch issue. my guess is the coil or worse the statetor. did you try a diff. plug first to rule that out. process of elimination is the best way.
Old Jun 9, 2006 | 09:11 AM
Predator72's Avatar
I did try a different plug, first thing, and it did the same thing. Is the coil under the hood?
Old Jun 9, 2006 | 10:25 PM
Freedom500's Avatar
The coil is under the hood. If you have a DVM you can check the coil. The primary coil should read about .3 ohms and the secondary should be between 5,000 - 7,000 ohms.
Old Jun 10, 2006 | 12:38 AM
gregery's Avatar
I have seen this happen on a friends 500. It turned out to be the stator.
I know this is not what you want to hear but I believe that is your problem.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
