DS 650 problem
Old Jun 8, 2006 | 12:48 AM
exhaustfumejunkie's Avatar
Default DS 650 problem
I have a 2000 DS 650 and I hit a rock and cracked the right hand side casing. It ran and started fine but just leaked oil. So I took the casing off and JB welded it. When I put it back together, the starter was binding and would not turn over, until I loosened all the bolts. But the bolts are too loose, and it leaks oil. Am I missing something? It cranks over just fine when the bolts are loose.
Old Jun 8, 2006 | 11:07 AM
Johnaua's Avatar
If you opened the case you are probably missing a washer (shim) inside, or it could be that your case got tweaked.
Old Jun 8, 2006 | 11:10 AM
There is a washer that goes on the starter shaft, is that the shim you are refering to?
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
