help on BOMB 90!!!!!!
Old Jun 12, 2006 | 06:04 PM
playtoy's Avatar
Default help on BOMB 90!!!!!!
I bought my son a 90 2-stroke like new.
Its slow!!!!!
I removed throttle stop
NO washer to be found in pipe or at head
no restictor to be found in airbox took off little pipe on back of pipe
Help this thing wont spin the tires!!
he was climbing a hill and it just stopped and won't spin the tires or go forward and it was pinned!!!
Please any info
Did I miss something??
Help!!!
THANKS
Old Jun 12, 2006 | 11:29 PM
05dsrider's Avatar
try going through the hole fuel system clean it absolutely throuroughly because we swapped engines and all kinds of stuff in 1 thinking it was a big problem and it ended up being dirt in the bottom of the tank
Old Jun 13, 2006 | 09:25 PM
playtoy's Avatar
Thank you for the help, but we tried that. Do you have anyother ideas?
Old Jun 13, 2006 | 11:35 PM
Doctorturbo's Avatar
GOT BOOST!
Start with the basics. Do a compression test. If that is ok then v
To make power you need flow. If you don't have any power, you need to check the flow.
First check the air filter.
Next would be the pipe. I have seen two stroke pipes so clogged up with carbon and oil they won't flow any air.
Old Jun 13, 2006 | 11:53 PM
DSNUT's Avatar
Its slow!!!!!
Please any info
Help!!!
THANKS
Did it stall on the way up the hill or was the motor still running when it came to a stop? What kind of tranny do these things have?
Old Jun 14, 2006 | 12:03 AM
BigDaddy331's Avatar
I've rebuilt three of them. DSNut has a good question. When it stopped, did the wheels stop and the motor just kind of plug, pluged along? If so, then it's one thing and one thing only. In the cvt clutch system there are 6 white rollers. They only need a couple of thousands of where before they go bad. They are very cheap. Just replace them and I'd be willing to bet that you'll be back in business. My son used to do the same thing on his BOMB 90. It was the fix every time. Since he's moved on, the quad went to a neighbor. He completely trashed it and I had to replace the shoe clutches as well as the rollers along with just about every other part on the bike. Doing hills and sand, kill the rollers. TRUST ME!
Old Jun 14, 2006 | 11:09 AM
playtoy's Avatar
thanks guys I will check the rollers
Airbox is clean
Bike has only been ridden 5 times since new by a beginner no hard stuff
motor is running on hill but bike stops no cut out it just sits like it trying to powerbrake
are these thing just this weak or are they supposed to spin the tires at least
thanks again all input is very usefull
Old Jun 14, 2006 | 11:30 AM
DSNUT's Avatar
Airbox is clean
You need to rebuild the cvt. It will run like a champ after you do that[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 15, 2006 | 10:35 PM
playtoy's Avatar
Thanks guys I'll try it and let you know!!
I can't believe its bad after only 5 time of being ridden?!
cctman
Jun 6, 2001 01:55 PM
BarryManilow
Dec 8, 2000 06:11 PM
bomberds
Dec 7, 2000 02:23 PM
