does bigger=power
Old Jun 21, 2006 | 10:17 PM
TBJAY's Avatar
Default does bigger=power
im looking for some low end power on a 2006 trail boss 330
now i dont know if this will do it but ill ask and find out
the rear sprocket more teeth = more low end or less teeth = more low end
im looking for more low end in the mud
Old Jun 21, 2006 | 10:19 PM
BigDog800EFI's Avatar
Bigger back sprocket will give you more low end power. You may also lose some top end speed.
Old Jun 21, 2006 | 10:50 PM
bberck's Avatar
Click for gear ratios
Old Jun 21, 2006 | 11:10 PM
ftwflh's Avatar
I wouldnt mess with the gearing.Try a K&N air filter and a EPI pink primary clutch spring.This will get you a better shift rate and keep you in the power range you need to be in.The filter will liven up the lowend some too.
Polaris are differant than the other brands.You tune your clutch to what you need rather than change sprockets most of the time.
Old Jun 21, 2006 | 11:29 PM
spyder6's Avatar
Rick Ritter from RCR also has some fantastic high performance products for your quad
Old Jun 21, 2006 | 11:52 PM
squeege's Avatar
Grab a ten speed bike and watch the rear sprocket see what gives you more power vs. speed
Old Jun 22, 2006 | 12:16 AM
TBJAY's Avatar
were would i get a new clutch spring?
Old Jun 22, 2006 | 07:58 AM
ftwflh's Avatar
Try www.erlandsonperformance.com or RcR for a spring.
Old Jun 22, 2006 | 08:19 AM
scootergptx's Avatar
Supersock
Hired Gun!
I'd definitely say give Rick a call. (618) 644-3211
Get the stage 1 kit, and ask for the pink EPI spring.
I got the kit for my 2000 and it really gave it some bottom end.
Old Jun 22, 2006 | 02:47 PM
scramblered's Avatar
it will not add power to the engine,but give more'usable' powerband at the trigger,polaris atvs' and sleds are generally geared too high for factory application,now if you want more low end,gear down a little,but
you'll need to follow close what the primary clutch is doing as to known what helix it should fit best in the secondary,it depend on engine compression and power and some others factor as altitude and air density.
make a black pencil mark on the primary sheaves til the very top to see what the system is at now,after a ride
(you must wide open throttle for a least 1/2 miles to fully close the sheaves)remove the clutch cover back
and you'll see what happen with the belt before going messed-up the gearing.
