sluggish recon
Old Jun 22, 2006 | 12:06 AM
bombrider04's Avatar
Default sluggish recon
My friend has a 2003 Honda Recon and hasn't been running right for a while now when you hit the throttle it seems to cut out and begins to die. So I took the carb apart and cleaned it all out and still nothing do you think it could be that the float in the carb needs adjusting or adjust the valves.
Thank Brett
Old Jun 22, 2006 | 01:54 PM
xtc's Avatar
xtc
Have you adjusted the idle screw on the carb yet? My wifes did the same thing because of low idle.I would also check for air intake restriction(if filters clean,leave the airbox lid off and ride to see if it's better that way)hope this helps..
Old Jun 22, 2006 | 04:44 PM
alright thanks next time I can get my hands on it ill try it out thanks for the help but ill check it.
COFatboy
May 2, 2020 12:06 AM
Hunter100us
Oct 7, 2015 11:46 PM
peytonius
Sep 28, 2015 02:18 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Hondamx751
Aug 13, 2015 01:06 AM
