LT80 mixture ratio
Old Jun 22, 2006 | 10:33 PM
mat050873's Avatar
Default LT80 mixture ratio
After removing the oil injector on an LT80, what should ratio should the fuel & oil be mixed at?
Old Jun 22, 2006 | 10:58 PM
Floorit's Avatar
I'm curious on the answer also. I heard that there's a bit more power there if you mix the gas yourself to the correct ratio.
I'm assuming the ratio will be 32:1
Old Jun 23, 2006 | 10:58 AM
LT80's Avatar
LT80 Expert
This depends on the oil used. Most oils 32:1 is just fine. There are some (ie: belray/amsoil) that are made for 50:1
The oils I recommend are::
Torco GP-7 (torcousa.com) this is the absolute best oil!
Klotz R-50
Maxima SuperM
QuadRiders
Oct 22, 2015 04:13 PM
Honski250r
Sep 26, 2015 09:40 PM
rockinkgin
Sep 25, 2015 01:52 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
