Need Help Doing Wireing Work
Old Jun 26, 2006 | 05:05 PM
Gavinater's Avatar
Default Need Help Doing Wireing Work
Hi i was wondering if anyone would be able to help me, i need to know how you wire up a 12volt outlet to your atv.
Old Jun 26, 2006 | 09:46 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum Gavinater. [img]i/expressions/face-icon-small-smile.gif[/img]
If you dont mind it having power all the time you could wire it directly to the battery.
Old Jul 3, 2006 | 10:15 AM
downeaster's Avatar
[img]i/expressions/face-icon-small-smile.gif[/img]This is an easy hookup. Go to napa or vip, where ever you decide, and look
for an 12v outlet similar to a cigarette lighter in you car. Choose one with a
cover so that you can have it somewhat waterproof when not in use. Drill a
hole somewhere on your machine to slip the component in. From here it is
a simple red wire black wire hookup. Red pos, and black neg. It would be
good if you ran your wire through some sort of snakeing or tubing from the
outlet to the battery. This would keep your wiring from burning up when your
machine get hot. (The cig lighter hook up is good because of there are so
many items out there that can plug in to it. (cellphone, Cig lighter, some
small radios, or mp3 players.) Good luck. Oh the center pin on the lighter
outlet is the positive, and the metal shell on the outside is negative.
Old Jul 3, 2006 | 10:40 PM
tencubed's Avatar
Being retired is a hoot!
Watch what kind of amperage rate is on the outlet you select. Some are rated at only 3 or 5 amps and may not be heavy duty enough for your needs. Also be sure to put a fuse in the positive wire, use a fuse that will not exceed the capacity of the outlet or the wire you use.
txkevin
Sep 21, 2015 02:02 PM
Ragtop
Jun 27, 2015 03:04 AM
BEEFKING69
Jun 17, 2015 12:38 AM
wildbill59
Jun 9, 2015 02:28 AM
clsharky
Jun 8, 2015 11:38 AM
