300ex binding problems
Old Jul 6, 2006 | 05:33 PM
ROOTYTOOTIE's Avatar
Default 300ex binding problems
While the atv is in motion it makes a poping noise, and it also makes the atv jerk.It feels like something is binding. I put it on a jackstand and it continued to do the same thing. I took the chain off and the jerking stopped. Can anyone help me? I'm not sure what it is!
Old Jul 6, 2006 | 05:38 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Kinked chain???? If so, chains are cheap. Replace it.
Old Jul 6, 2006 | 06:49 PM
ElectricShift's Avatar
back brake catching?
Old Jul 8, 2006 | 08:22 PM
HR's Avatar
HR
sounds like the rear spocket is warn and you need a new one. maybe the front but more then likely the rear. you should get a new chain with the new spocket or your old chain will wear the new sprocket out faster.
HR
Old Jul 8, 2006 | 09:56 PM
Floorit's Avatar
I tend to agree with it being the rear sprocket or chain.
Being TOO loose can cause this popping sound.
A wore rear sprocket and/or chain can cause this popping sound.
If the chain & sprockets appear to be in good shape still, it may be caused from lack of lubrication in the chain. The chain can be soaked in diesel fuel which will loosen it up. While it's in the diesel, work the chain in every direction you can to break the crud up and help things go a bit faster. Then ....let the chain sit in the diesel overnight.
After letting it sit over night, soak it in gasoline to remove the diesel [oils]. Dry it with an air compressor [outside as it will throw stuff EVERYWHERE]
Next....put it back on the bike, add a good coat of chainlube as you spin the wheels.
If it does nothing for the popping sound, I recommend getting a new chain & sprocket set.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
