remove two or three rollers
Old Jul 12, 2006 | 06:47 PM
BALDY's Avatar
Default remove two or three rollers
Hey guys , my buddy and I talked to a guy at a bike shop the other day about removing the rollers on the lt 80. I have been on the site for a while now and the talk is too remove 2 rollers.The guy at the shop told us to remove three and he is a self proclaimed guru on the 80s.I know mr lt80, says on this sight to only remove two. My buddy removed three and his worked fine for now.what is the long term effects on removing 3...I have been connected to this site for a while and if "LT80" says to only remove 2 then thats what i'll do.Is there anything that I need to tell my buddy about future problems with removing 3, if any.Thanks up front for the replys....
Old Jul 12, 2006 | 07:09 PM
billl2099's Avatar
the only down side to removing 3 rollers instead of 2 is you might loose a little top speed, but should increase bottom end performance
Old Jul 12, 2006 | 07:14 PM
Fastestdad's Avatar
You'r motor may be pulling more rpm than it should, basically going past it's powerband. LT80 messes with the LT80 constantly so I'd say 2 is good and has my vote. Now if we could ever just get him to come over to the dark side with us 90cc 2 stroke racers he'd be even faster. LOL
Old Jul 13, 2006 | 02:10 AM
maggiesboy's Avatar
"One Wheel Short"
Jack made a comment a while back that removing rollers will not affect top end. Removing the rollers will increase stall speed.
Old Jul 13, 2006 | 10:08 AM
billl2099's Avatar
it does affect top speed , if you don't use enought weight the variator doesn't open all the way and won't allow the drive belt to slide to the bottom of variator, you can verify this by using a gps before removing and after removing the weights
Old Jul 13, 2006 | 12:56 PM
Hymis's Avatar
Jack built my sons LT80 listed under the topic " some other lt80 pics " I had to remove 3 rollers to get the desired stall speed. You can also drill out the rollers to get the correct roller weight your looking for.
Old Jul 14, 2006 | 12:36 PM
LT80's Avatar
LT80 Expert
For a stock engine, removing 2 is all that's needed. Removing 3 may increase the stall over removing 2 but it may take off slower cuz the clutch isn't being pushed hard from too little weight. Top speed will be effected by removing 3 IMO (Bills correct). All your llooking for is a better start (stall), the LT in stock form grunts well IMO.
Your buddy shouldn't have any long term effects as far as damage goes.
Again, this is for a stock motor/pipe.
Hymis quad is highly modified and uses a Trinity pipe. Once modded and piped, all the above changes.
Who's the guru (I wonder if know him)?
Dark side?? 2 stroke racers?? I thought I was there. [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
Truth be known, the "other" motors that I've built are a tad faster than my LT80 motors. Now if I'd only change my nickname to:: kasetodinanymotor. LMAO!![img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
hey maggiesboy:: CONGRATS ON THE MAG PIC!!!!!!!! (I do think that 2 doesn't effect top speed but 3 does).[img]i/expressions/face-icon-small-smile.gif[/img]
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
